Veho ZB-6 On-Ear Wireless Bluetooth Headphones
£56.32
34 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Built-in rechargeable battery allowing up to 24 hours continuous music playback
  • Connect via 4.1 Bluetooth for wireless listening or use optional 3.5mm aux jack
  • Well balanced mids and high fidelity treble delivering a premium audio experience
  • Noise isolating super soft ear cups and Tacton rubber touch for a stylish finish
  • Take voice calls and control your music with the multi-function on-ear controls
  • Accessory Type: Headphones
  • Connectivity: Wireless
  • Colour: Black
  • Stock Status: In Stock
Product codes
Enjoy up to 24 hours of uninterrupted wireless music from a single charge, with the ZB-6 on-ear headphones from the Veho Z-Series audio range.
The Veho ZB-6’s feature low energy 4.1 Bluetooth connectivity, ideal for connecting up wirelessly to the Apple iPhone 7, iPhone 7 Plus, Android Smartphones or other Bluetooth devices such as, PC’s, tablets and MP3 players.
The 40mm acoustic drivers deliver a premium audio quality, with well-balanced mids and high fidelity treble, producing an enhanced listening experience. The Veho ZB-6’s also feature noise isolating technology, which means they’re are ideal for commuting, watching movies, the gym or for general everyday use.
Take voice calls and control your music’s track selection or volume thanks to the built-in microphone and remote control on the ear-cups. The Veho ZB-6’s also support voice commands for Siri and Google Now.
The built in 3.5mm auxiliary port make the ZB-6 headphones compatible with any standard AUX connections and will enable the ZB-6 to work as standard headphones when out of battery. The folding design makes them easy to store in your bag and allow you to take them anywhere you want.
Key Features
  • Take voice calls and control your music with the multi-function on-ear controls.
Box Contents
  • Veho ZB-6 Bluetooth headphones
  • 120cm auxiliary cable with 3.5mm jack
  • Micro USB to USB-A charging cable
  • Multi lingual user manual (English, French, Spanish, German, Italian, Portuguese, Japanese & Chinese).
Product Description Veho ZB-6 - headphones with mic
Product Type Headphones - Bluetooth - wireless
Compatibility iPhone, Android phone
Recommended Use Portable electronics
Headphones Form Factor On-ear
Connectivity Technology Wireless
Wireless Technology Bluetooth
Radio Frequency Range 2.402 - 2.480GHz
Bluetooth Version Bluetooth 4.1 EDR
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
Impedance 32 Ohm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho ZB-6 On-Ear Wirel...
£56.32
