Veho ZS-2 Water Resistant Sports Earphones – Yellow/Black
£7.93
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Small, lightweight and designed for the active lifestyle
  • Water, rain and sweat resistant
  • 3.5 mm AUX jack is compatible with line-in ports
  • Comfortable non-slip rubber earbud, ensuring the earphones stay fitted perfectly in your ear during any vigorous workout
  • Thin acoustic drivers with base enhancement and crisp sound
  • Recommended Use: Portable electronics
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
These stereo earphones are small, lightweight and designed for the active lifestyle. They come in a water, rain and sweat resistant body with a cord and are IP64 rated, which means that these sports earphones will be protected from total dust ingress and waterspray from any direction. The cable features the popular flat flex anti-tangle durable cord system and the hook design to fit over the ears and is comfortable with almost any helmets and goggles / glasses. A comfortable non-slip rubber earbud ensures they fit perfectly in your ear during any vigorous workout. The acoustic drivers give you better base and crisper sound, so not only do they look good they sound great. These earphones are ideal for gym workouts, cycling, running, skiing, snowboarding, skateboarding and other indoor and outdoor sports activity.
Product Description Veho ZS-2 - earphones
Product Type Earphones - wired - 3.5 mm jack
Recommended Use Portable electronics
Style Sports
Colour Yellow/black
Headphones Form Factor In-ear - over-the-ear mount
Connectivity Technology Wired
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance 16 Ohm
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Veho ZS-2 Water Resist...
£7.93
