Verbatim Datalife 48/52x Spindle 100PK
£12.19
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Media Type: CD-R
  • Max Speed: 52x
  • Pack Size: 100
  • Capacity: 700MB
  • Stock Status: In Stock
Product codes
CD-R is short for "CD-Recordable". The discs are also known as WORM media, which stands for Write Once, Read Multiple. The advantage of CD-R over other types of optical media is that you can use the discs with a standard CD player. A related technology called CD-Rewritable (CD-RW) allows you to erase discs and reuse them, but the CD-RW media does not necessarily work in all players as technology has changed since certain models were brought out. The mechanical specifications of Verbatim media are very precise, and data written to it can be read in a wide range of drives.
Product Description Verbatim - CD-R x 100 - 700 MB - storage media
Type Storage media - CD-R
Media Included Qty 100
Native Capacity 700 MB
Recording Time 80min
Write Speed 52x (max)
Features Extra Protection Surface
Package Type Spindle
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Verbatim Datalife 48/5...
£12.19
