Verbatim Primalloy 1.75mm 500g Reel - White
£38.95
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Recommended for use in commonly available fused filament fabrication (FFF) 3D printers
  • Print only in a well-ventilated or hooded work area
  • Best results obtained with printers having a heated platform (40-50 °C)
  • The extruded material adheres to a build platform that has been covered with polyimide tape
  • Keep material sealed until ready for use
  • To control moisture content, return any partially consumed reel to a sealed, air-tight bag that contains a desiccant
  • To prevent layer drooping, apply forced air cooling on object as it builds
  • To prevent feed jams, apply slow print speeds (=30 mm/s) and turn off retraction
  • Avoid excessive pressure in the pinch feeder
  • Due to its flexibility and resultant buckling risk, this filament is not recommended for printers with significant distance (e.g. >15 mm) between pinch feeder and hot end
Product codes
Primalloy is a soft rubber material with outstanding heat, oil and abrasion resistance and mechanical strength. It is a high performance polyester based thermoplastic elastomer (TPE). Exceptional diameter consistency provides great homogeneous wire structure for smooth operation. Primalloy is a registered trademark of Mitsubishi Chemical Corporation. All filament is delivered in a vacuum bag, with desiccant, wound onto a bespoke spool.
Verbatim Primalloy - white - TPE filament
TPE filament
Filament Diameter
1.75 mm
500 g
Printing Technology
FDM
Printing Colour
White
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Verbatim Primalloy 1.7...
£38.95
