Wacom Bamboo Stylus Duo 4 - Black
£24.49
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Combined stylus and inking pen without compromises to provide the best experience in both worlds
  • Improves experiences with applications for sketching
  • Elegant platinum silver and black finish with satin-textured plated metal KeySellingPoints
  • Weight-balanced design
  • Soft rubber rings for a smooth fit of the cap on both tip ends
Product codes
Do you belong to the group of people who fully embrace mobile computing, but now and then make a quick note on a piece of paper or in a notebook? Then Bamboo Stylus duo is the perfect solution for you.
Because Bamboo Stylus duo has two nibs, one responsive smooth pen tip for media tablets and one inking tip for using on paper, you can simply switch between working on the touch screen and traditional paper by the flip of the pen. The pen's cap can be attached to either end, so the tip that isn't used will remain protected.
Bamboo Stylus duo ensures the most natural pen experience, regardless what media you are using. The best-in-class responsive smooth pen tip provides a smooth and authentic stylus-on-screen feeling with increased precision thanks to the slimmer pen tip compared to other most popular solutions on the market. The inking nib uses standard refills and hence delivers a writing sensation similar to regular ballpoint pens.
With its sophisticated premium design composed of a plain and clean shape, Bamboo Stylus duo is the result of Wacom's 25 years of experience in the design of digital pen tablets. This knowledge is further reflected in the implementation of the pen cap that shields the pen tip that's not in use.
Wacom Bamboo Duo - stylus / ballpen
Stylus / ballpen
0.9 cm
Length
14.1 cm
15 g
Blue
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Wacom Bamboo Stylus Du...
£24.49
