Wacom Cintiq 27" QHD Touch (Pen & Touch Input) Graph...
Wacom Cintiq 27" QHD Touch (Pen & Touch Input) Graphics Display
Key features
  • It takes millions of pixels to make colors look this sharp
  • Spend more time creating
Product codes
The Cintiq 27QHD Touch creative pen displays set a new standard in color and resolution. The most natural form of creative expression meets an advanced interface design that re-imagines the creative workflow so you don't have to adapt to the tool - the tool adapts to you. Work with hands-on fluidity as you create with a pressure-sensitive pen and multi-touch gestures directly on an expansive, edgeless glass display.
The Cintiq 27QHD's 27" widescreen 16:9 display offers the highest resolution of any Cintiq (2560 x 1440). Featuring 97% Adobe RGB, 1.07 billion colors and REC 709, this premium color display is the ultimate tool for color sensitive workflows.
The Cintiq 27QHD Touch allows you to immerse yourself in your work by using Multi-Touch gestures in applications such as Photoshop and Adobe Illustrator CC to position and navigate your work with one hand while you create with the pressure-sensitive pen in the other.
The ExpressKey Remote can be positioned anywhere on the screen for a faster, more flexible workflow. Customize the ExpressKeys on the remote with your favorite shortcuts, and use the Touch Ring to zoom, rotate or change brush sizes. Spend less time searching for the correct shortcut and more time getting lost in your ideas.
Choose your working position and stand: place the Cintiq 27QHD Touch on your desk for either a 5° slope or foldout the sturdy legs for a 20° angle.
The Cintiq 27QHD Touch Pro Pen features Wacom's proprietary Tip Sensor technology, which offers users near-zero (one gram) starting pressure and virtually the same natural experience as one working with traditional brushes or pens. The pen also features a pressure-sensitive eraser and two side switches that can be customized for common commands, such as double-click and right-click. The pen includes 2048 levels of pressure sensitivity and 40° pen tilt recognition.
Compatible with both Mac and PC platforms, the Cintiq 27QHD works seamlessly with your computer's configuration, including another Cintiq, an Intuos pen tablet, or your existing mouse.
Product Description Wacom Cintiq 27QHD Touch - digitiser - USB - black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Wacom Cintiq 27" QHD T...
