Wacom DTK-2241 Interactive Display
Key features
  • 21.5" IPS display with Full HD (1920 x 1080) resolution and wide viewing angles
  • Cordless and battery-free pen with 2 side-switches, 1024 levels of pressure sensitivity
  • 5 user-assignable ExpressKeys to access common functions or tools
  • Integrated USB hub with 2 USB ports to provide easy access to your favorite USB devices
  • Internal scaler will take video input signals in different resolutions and display them in their native resolution and aspect ratio
  • Built-in DVI-I pass-thru connector handles either digital or analog input and allows mirroring directly from the pen display to a projector or another display
  • HDCP compliant
  • Completely flat, textured, anti-glare surface
  • Adjustable stand that allows for 15 to 72 degrees of incline
Product codes
The DTK-2241 combines a 21.5", 16:9 widescreen LCD with Wacom's patented, cordless, battery-free pen technology and 5 user-assignable ExpressKeys.
The DTK-2241 interactive pen display is a premium communication tool. The impressive 21.5" LCD with high resolution and wide viewing angle provides a large screen for users to work on. It is optimal for streamlining the electronic documents workflow within education, healthcare and business settings. Mark up and annotate presentations or lesson plans for interactive teaching; complete electronic forms using digital ink; and capture signatures directly in documents. Five customizable ExpressKeys provide additional convenience by offering easy access to shortcuts and commonly used functions.
Wacom DTK-2241 - digitiser - USB
Digitiser
Wireless - USB
Display
LCD display - 21.5" - 1920 x 1080
56.6 cm x 38.5 cm x 5.5 cm
6.55 kg
Movement Detection Technology
Electromagnetic
Accuracy
± 0.5 mm
Pressure sensitive pen, eraser, built-in 2-ports USB hub
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Vista SP2, Microsoft Windows XP SP3, Microsoft Windows 7 SP1 or later, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8 64-bit Edition
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Wacom DTK-2241 Interac...
