Built for 24/7, always-on, high-definition security systems. With an impressive workload rate and support for many cameras, WD Purple drives are optimized for surveillance systems.
Product Description | WD Purple WD121PURZ - hard drive - 12 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 12 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | Time-Limited Error Recovery (TLER), Advanced Format technology, HelioSeal, surveillance system compatible, 24x7 continuous operation, AllFrame AI | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 660 g | Localisation | Worldwide | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 12 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 660 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 235 MBps |
Reliability | |
MTBF | 1,500,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 6.6 Watt (read) , 6.6 Watt (write) , 5.6 Watt (idle) , 0.6 Watt (standby) , 0.6 Watt (sleep) |
Miscellaneous | |
Compliant Standards | RoHS, Directive 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 65 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 30 g @ 2 ms |
Shock Tolerance (non-operating) | 250 g @ 2 ms |
Sound Emission | 20 dBA |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
