WD 14TB Ultrastar DC HC530 7200 RPM SATA 3.5" 256MB Ente...
WD 14TB Ultrastar DC HC530 7200 RPM SATA 3.5" 256MB Enterprise Hard Drive
£547.36
Delivery:
Standard: 1-3 working days
Key features
  • CMR technology works seamlessly in capacity enterprise applications & environments
  • Reliable, field-proven, 5th generation design
  • HelioSeal design delivers outstanding power efficiency (Watts/TB)
  • TDMR and improved dual-stage microactuator provide optimal head positioning and rotational vibration robustness
  • Form Factor: 3.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-150
  • Capacity: 14TB
  • Spin Speed (rpm): 7200rpm
Product codes
The breadth and depth of big data is driving the universal need for higher capacities across a broad spectrum of applications and workloads. Laying the foundation for a worryfree data center, Western Digital delivers capacity to conquer the data explosion - the Ultrastar DC HC530 hard drive. Built using HelioSeal technology, the fifth generation helium platform and the basis for the high-capacity DC HC500 series, Ultrastar DC HC530 was designed for public and private cloud environments where storage density, Watts/TB and $/TB are critical parameters for creating a cost-efficient infrastructure. HelioSeal technology is key to achieving higher drive capacities, higher reliability ratings and extreme power efficiency for lower levels of total cost of ownership (TCO) for cloud and enterprise customers.
Product Description WD Ultrastar DC HC530 WUH721414ALE6L4 - hard drive - 14 TB - SATA
Type Hard drive - internal (desktop)
Capacity 14 TB
Form Factor 3.5" (in 3.5" carrier)
Interface SATA
Buffer Size 512 MB
Spindle Speed 7200 rpm
Features HelioSeal, 512 emulation ( 512e )
Dimensions (WxDxH) 101.6 mm x 147 mm x 26.1 mm
Weight 690 g
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 14TB Ultrastar DC H...
£547.36
