The WD Gold is a highly reliable solution for demanding storage environments. Specifically designed for use in enterprise-class storage systems and data centers, the WD Gold Enterprise Class SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
Product Description | WD Gold WD161KRYZ - hard drive - 16 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 16 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 512 MB | Spindle Speed | 7200 rpm | Features | Vibration dampening, HelioSeal, 24x7 continuous operation, advanced format 512e, Energy-Assisted Magnetic Recording (EAMR), Triple State Actuator (TSA) | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 690 g | Localisation | Worldwide | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 16 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 690 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 262 MBps |
Reliability | |
MTBF | 2,500,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 6.5 Watt (active) , 5.6 Watt (idle) |
Miscellaneous | |
Compliant Standards | RoHS 2011/65/EU |
Dimensions & Weight (Shipping) | |
Shipping Width | 12.7 cm |
Shipping Depth | 6.35 cm |
Shipping Height | 19.05 cm |
Shipping Weight | 830 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 50 g @ 2 ms half-sine wave |
Shock Tolerance (non-operating) | 250 g @ 2 ms half-sine wave |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
