Boost your PC storage with WD Blue drives, the brand designed just for desktop and all-in-one PCs with a variety of storage capacities.
Product Description | WD Blue WD10SPZX - hard drive - 1 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 1 TB | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 5400 rpm | Features | Advanced Format technology | Dimensions (WxDxH) | 69.67 mm x 100.2 mm x 7 mm | Weight | 90 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 1 TB |
Width | 69.67 mm |
Depth | 100.2 mm |
Height | 7 mm |
Weight | 90 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Start / Stop Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 2.5" |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 65 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
