WD 1TB Blue 2.5" SATA 5400RPM Internal Hard Drive Mobile
£44.23
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • An excellent solution for your everyday computing needs
  • Plan for the future
  • Form Factor: 2.5"
  • Type: Hard drive
  • Capacity: 1TB, 1TB
  • Spin Speed (rpm): 5400rpm
  • Stock Status: In Stock
Product codes
Boost your PC storage with WD Blue drives, the brand designed just for desktop and all-in-one PCs with a variety of storage capacities.
Product Description WD Blue WD10SPZX - hard drive - 1 TB - SATA 6Gb/s
Type Hard drive - internal - Advanced Format technology
Capacity 1 TB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 128 MB
Spindle Speed 5400 rpm
Features Advanced Format technology
Dimensions (WxDxH) 69.67 mm x 100.2 mm x 7 mm
Weight 90 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 1TB Blue 2.5" SATA...
£44.23
