Boost your PC storage with WD Blue drives, the brand designed just for desktop and all-in-one PCs with a variety of storage capacities.
Product Description | WD Blue WD10SPZX - hard drive - 1 TB - SATA 6Gb/s | Type | Hard drive - internal - Advanced Format technology | Capacity | 1 TB | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 5400 rpm | Features | Advanced Format technology | Dimensions (WxDxH) | 69.67 mm x 100.2 mm x 7 mm | Weight | 90 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 1 TB |
Width | 69.67 mm |
Depth | 100.2 mm |
Height | 7 mm |
Weight | 90 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Start / Stop Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 2.5" |
Miscellaneous | |
Compliant Standards | RoHS |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 65 °C |
