WD 1TB My Passport SSD USB 3.1 - Portable SSD
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Blazing-fast file transfers with speeds up to 540 MB/s
  • Password protection with hardware encryption
  • USB Type-C and USB 3.1 Gen 2 ready; USB 3.0, USB 2.0 and USB-A compatible
  • Trusted drive built with WD reliability
  • Automatic backup
  • Easy to use
  • Capacity: 1024GB
  • Interface: USB 3.1 Gen 2
  • Type: External hard drive
  • Stock Status: In Stock
Product codes
The My Passport SSD is portable storage with blazing-fast transfers. Password protection with hardware encryption helps keep your content secure. Easy to use, the My Passport SSD is shock-resistant, compact storage in a cool, durable design.
Product Description WD My Passport SSD WDBKVX0010PSL - solid state drive - 1024 GB - USB 3.1 Gen 2
Type Solid state drive - external (portable) - shock resistant, password authentication, automatic backup, Apple Time Machine compatible
Capacity 1024 GB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface USB 3.1 Gen 2 - USB-C
Data Transfer Rate 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Shock resistant, password authentication, automatic backup, Apple Time Machine compatible
Power Source USB bus
Enclosure Colour Black top with gunmetal (medium metallic grey) bottom
Dimensions (WxDxH) 45 mm x 90 mm x 10 mm
Localisation Worldwide (excluding China)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 1TB My Passport SSD...
£177.19
