The My Passport Wireless SSD is an all-in-one portable drive that helps preserve photos and videos captured on your cameras and drones. The one-touch copy button lets you back up photos and videos with the built in SD card reader or the integrated USB port without a laptop or software.
Product Description | WD My Passport Wireless SSD WDBAMJ0010BGY - wireless mobile storage - 1 TB | Device Type | Wireless mobile storage | Host Connectivity | USB 3.0 / 802.11ac | Total Storage Capacity | 1 TB | Dimensions (WxDxH) | 13.5 cm x 13.5 cm x 3 cm | Weight | 460 g | Localisation | Middle East, Africa, Europe | Hard Drive | 1 x 1 TB | Card Reader | Yes | Networking | USB 2.0, 802.11b/g/n, USB 3.0, 802.11ac | Power | AC 120/230 V (50/60 Hz) | System Requirements | Android 4.4 (KitKat) or later, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple MacOS X 10.12, Apple iOS 9 or later, Apple MacOS X 10.13 | Manufacturer Warranty | 2-year warranty |
General | |
Width | 13.5 cm |
Depth | 13.5 cm |
Height | 3 cm |
Weight | 460 g |
Built-in Devices | Power bank (6000 mAh) |
Hard Drive | |
Type | SSD |
Capacity | 1 x 1 TB |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | SD Memory Card |
Networking | |
Data Link Protocol | USB 2.0, 802.11b/g/n, USB 3.0, 802.11ac |
Features | UPnP Media Server, DLNA Media Server, Plex Media Server |
Compliant Standards | IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac |
Expansion / Connectivity | |
Interfaces | 1 x USB 3.0 , 1 x USB 2.0 |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable |
Included Accessories | Protective cover |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Battery | |
Run Time (Up To) | 10 hours |
Software / System Requirements | |
OS Required | Android 4.4 (KitKat) or later, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple MacOS X 10.12, Apple iOS 9 or later, Apple MacOS X 10.13 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 80% |
