WD 2TB Blue Mobile 2.5" 7mm SATA 6Gb/s 128MB Cache
£79.10
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • SATA 6 Gb/s interface
  • NoTouch ramp load technology
  • High quality
  • Low power consumption
  • Quiet
  • Form Factor: 2.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 2TB
  • Spin Speed (rpm): 5400rpm
Product codes
WD Blue hard drives deliver solid performance and reliability while providing you with all of the space you need to hold enormous amounts of photos, videos, and files. WD Blue hard drives are designed for use as primary drives in notebooks and external enclosures.
Product Description WD Blue WD20SPZX - hard drive - 2 TB - SATA 6Gb/s
Type Hard drive - internal - NoTouch ramp load technology, Advanced Format technology
Capacity 2 TB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 128 MB
Spindle Speed 5400 rpm
Features NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
Dimensions (WxDxH) 69.85 mm x 100.2 mm x 7 mm
Weight 90 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 2TB Blue Mobile 2.5...
£79.10
