EE + BT. BETTER AS ONE. WE’RE PART OF THE SAME FAMILY.
WD 2TB Red NAS Hard Drive 3.5" 256MB Cache
£67.32
43 In Stock
Delivery:
Standard: 3-5 working days
Key features
  • Beyond desktop with NASware
  • Important features for system integrators
  • Save power and money
  • Intelligent error recovery
  • Command completion
  • Form Factor: 3.5
  • Type: Hard drive
  • Capacity: 2TB
  • Spin Speed (rpm): 5400rpm
Product codes
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
Product Description WD Red WD20EFAX - hard drive - 2 TB - SATA 6Gb/s
Type Hard drive - internal
Capacity 2 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 5400 rpm
Features Native Command Queuing (NCQ), Advanced Format technology, NASware technology, 24x7 continuous operation, Error Recovery Control
Dimensions (WxDxH) 101.6 mm x 147 mm x 26.1 mm
Weight 600 g
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer
Ref: FLRB 047060
£61.77
product
Ref: FLRB 047060
Accessories
Packaging
Functional
Software
Manuals
£61.77
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£67.32
