WD 3TB Elements USB 3.0 3.5" Desktop Hard Drive
£75.12
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Transfer files faster than ever
  • Massive capacity
  • Improve PC performance
  • Universal connectivity
  • Plug-and-Play simplicity
  • Form Factor: 3.5"
  • Capacity: 3TB
  • Interface: SuperSpeed USB
  • Stock Status: In Stock
Product codes
WD Elements™ desktop storage with USB 3.0 offer reliable, high-capacity, add-on storage, ultra-fast data transfer rates, universal connectivity, and 3 TB capacity. Includes a free trial of WD SmartWare™ Pro automatic backup software.
  • USB 3.0 and USB 2.0 compatibility - With this single drive you get compatibility with the latest USB 3.0 devices and backward compatibility with USB 2.0 devices as well.
  • Maximum transfer rates - When connected to a USB 3.0 port, WD Elements desktop storage delivers ultra-fast data transfer rates.
  • Improve PC performance - When your internal hard drive is almost full your PC slows down. Don't delete files. Free up space on your internal hard drive by transferring files to your WD Elements desktop storage and get your computer moving again.
  • Massive capacity in a sleek design - The sleek design offers up to 3 TB capacity, making WD Elements desktop storage the ideal solution for easy, add-on storage of all your important photos, music, videos and files.
  • Free trial of WD SmartWare™ Pro backup software - WD Elements desktop storage comes with a trial version of WD SmartWare™ Pro backup software. This backup software allows you to back up your files to your WD Elements drive or to the cloud using your DropBox™ account.
  • WD quality inside and out - We know your data is important to you. So we build the drive inside to our demanding requirements for durability, shock tolerance, and long-term reliability. Then we protect the drive with a durable enclosure designed for style and protection.
  • Formatted for Windows® - Formatted NTFS and compatible with Windows 8, Windows 7, Windows Vista® or Windows XP. Can be reformatted for Mac®.
Product Description WD Elements Desktop WDBWLG0030HBK - hard drive - 3 TB - USB 3.0
Type Hard drive - external (desktop) - NTFS formatted
Capacity 3 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features NTFS formatted
Power Source Included AC adapter
Dimensions (WxDxH) 48 mm x 135 mm x 165.8 mm
Weight 910 g
Localisation United Kingdom
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 3TB Elements USB 3....
£75.12
