WD 3TB My Book 3.5" USB3.0 Desktop Hard Drive
Select:
Key features
  • Complete backup
  • Password protection
  • Reimagined design
  • Easy to use
Product codes
My Book
The My Book desktop hard drive is designed to complement your personal style with a massive amount of space to store your photos, videos, music and documents.
Complete Backup, Time Machine-Compatible
Equipped with WD Backup software for Windows and Apple Time Machine compatibility for Mac, the My Book desktop hard drive can back up your photos, videos, music and documents. The My Book desktop hard drive also works great with Acronis True Image WD Edition software to schedule full system backups.
Password Protection with Hardware Encryption
With built-in 256-bit AES hardware encryption with WD Security software, you can set your own personalized password to help keep your content private and safe.
Easy to Use
Ready to use out of the box, start transferring files, saving memories and backing up. WD Backup and WD Security software are included to help protect your data. The My Book drive is also compatible with Apple Time Machine.
Reimagined Design
The compact design of the My Book drive exudes a confidence reflective of its reliability. With up to 8TB of storage capacity, you can trust your My Book drive to be the home of your digital life.
Massive Capacity
With up to 8TB of capacity, there's plenty of room to save the massive amounts of photos, videos, and music you love, plus your important documents.
WD Quality Inside and Out
Millions of people around the world trust their data to the My Book desktop hard drive. Designed to meet WD's demanding requirements for durability, shock tolerance and long-term reliability, we stand by the trusted My Book desktop storage with a 2-year limited warranty
Product Description WD My Book WDBBGB0030HBK - hard drive - 3 TB - USB 3.0
Type Hard drive - external (desktop) - password authentication, hardware encryption, automatic backup, Apple Time Machine compatible, exFAT formatted
Capacity 3 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Password authentication, hardware encryption, automatic backup, Apple Time Machine compatible, exFAT formatted
Power Source Included AC adapter
Enclosure Colour Black
Dimensions (WxDxH) 49 mm x 139.3 mm x 170.6 mm
Weight 960 g
Localisation EMEA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
