WD 3TB My Passport for Mac 2.5" USB 3.0 Portable Hard Drive
Select:
  • 3TB
Key features
  • Secure and reliable
  • Compatible with Apple Time Machine
  • Sleek design with high capacity
  • Ultra-fast transfer rates
  • You're in control
Product codes
My Passport for Mac
My Passport for Mac is the sleek, portable hard drive designed for photographers, graphics professionals and road-warriors who want to take their digital life with them. It's compatible with Apple Time Machine and is an ideal companion for your MacBook or MacBook Air. Password protection and hardware encryption let you secure your files from unauthorized access.
Built for Mac, Time Machine-Ready
Ready to go with your Mac straight out of the box, the My Passport for Mac drive helps protect your files with Apple Time Machine backup software. And you can quickly drag and drop files to and from the drive with Finder.
Password Protection with Hardware Encryption
Built-in 256-bit AES hardware encryption with WD Security software helps keep your content private and safe. Add a 'return-if-found' message as the password prompt in case your My Passport for Mac drive ever gets lost.
Easy to Use
Ready to use out of the box with your Mac, you can start transferring files, saving memories and backing up. The My Passport for Mac drive works with Apple Time Machine, and included WD Security software helps protect your data.
Reimagined Design
Designed to complement your Mac, the rich, black shine and artful composition makes the My Passport for Mac drive fashionably fun.
Massive Capacity
With up to 4TB, you can take the massive amounts of photos, music and videos you love wherever you go, and have plenty of room for other important documents, too.
WD Quality Inside and Out
WD builds drives to demanding requirements for durability, shock tolerance and long-term reliability. And we stand behind the trusted My Passport for Mac drive with a 2-year limited warranty.
WD My Passport for Mac WDBP6A0030BBK - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption, automatic backup, Apple Time Machine compatible, HFS+ formatted
Power Source
USB bus
Enclosure Colour
110 mm x 81.5 mm x 21.5 mm
250 g
Worldwide (excluding China)
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 3TB My Passport for...
