WD 4TB Black 3.5" SATA 6Gb/s 7200RPM 128MB Hard Drive
£181.76
24 in stock
Delivery:
Standard: 1-3 working days
  • Form Factor: 3.5"
  • Type: Hard drive
  • Capacity: 4TB
  • Spin Speed (rpm): 7200rpm
  • Stock Status: In Stock
Product codes
WD Black performance storage is designed to enhance your PC experience across heavier computing tasks whether you are a digital artist, video editor, photographer, or gamer. Available with up to 256MB of DRAM cache on higher capacity models, the WD Black drive is optimized for drive performance so you can spend more time experiencing the things you love most.
Product Description WD Black WD4005FZBX - hard drive - 4 TB - SATA 6Gb/s
Type Hard drive - internal - StableTrac, Advanced Format technology, DRAM cache
Capacity 4 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features StableTrac, Advanced Format technology, DRAM cache
Dimensions (WxDxH) 101.6 mm x 147 mm x 26.1 mm
Weight 720 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 4TB Black 3.5" SATA...
£181.76
