WD 4TB My Passport 2.5" USB 3.0 Portable Hard Drive - Red
£106.20
Delivery:
Standard: 1-3 working days
Key features
  • Slim design
  • Automatic backup - easy to use
  • Password protection and 256-bit AES hardware encryption
  • Trusted drive built with WD reliability
  • SuperSpeed USB port; USB 2.0 compatible
  • Type: Hard drive
  • Capacity: 4TB
  • Stock Status: In Stock
Product codes
Every journey needs a passport. The My Passport drive is trusted, portable storage that gives you the confidence and freedom to drive forward in life. With a stylish design that fits in the palm of your hand, there's space to store, organize, and share your photos, videos, music, and documents. Perfectly paired with WD Backup software and password protection, the My Passport drive helps keep your digital life's contents safe.
Product Description WD My Passport WDBPKJ0040BRD - hard drive - 4 TB - USB 3.2 Gen 1
Type Hard drive - external (portable)
Capacity 4 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface USB 3.2 Gen 1
Data Transfer Rate 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Password authentication, automatic backup
Power Source USB bus
Enclosure Colour Red
Dimensions (WxDxH) 75 mm x 107.2 mm x 19.15 mm
Weight 210 g
Localisation Worldwide (excluding China)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£106.20
