WD 500GB Blue 3.5" SATA 6Gb/s 7200rpm 32MB Hard Drive
£44.13
27 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Trusted engineering
  • A modern classic
  • Your power of choice
  • Recommended use
  • Form Factor: 3.5" x 1/3H
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 500GB, 500GB
  • Spin Speed (rpm): 7200rpm
Product codes
Built to WD's highest standards of quality and reliability, WD Blue offers the features and entry-level capacities that are ideal for your computing needs. WD Blue is designed by the brand that you trust with the quality you would expect for a tested, proven, everyday storage solution.
WD Blue storage is designed and manufactured with technology found in WD's original award-winning desktop and mobile hard drives. WD Blue sets the baseline for everyday storage by consistently delivering improved performance over previous generations while successfully maintaining WD's quality and reliability for over six generations. The difference is that their colors never fade, generation after generation.
WD Blue is available in a broad range of entry-level capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system. However, not all hard drives are created equally and for your applications that demand more, WD gives you the power of choice.
Product Description WD Blue WD5000AZLX - hard drive - 500 GB - SATA 6Gb/s
Type Hard drive - internal
Capacity 500 GB
Form Factor 3.5" x 1/3H
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 32 MB
Spindle Speed 7200 rpm
Features NoTouch ramp load technology, S.M.A.R.T.
Dimensions (WxDxH) 101.6 mm x 147 mm x 25.4 mm
Weight 440 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£44.13
