WD 500GB Blue 3D NAND SATA 6GB/s 2.5" SSD
£53.95
Select:
Delivery:
Key features
  • Leading-edge reliability
  • High capacity with enhanced reliability
  • Enhanced power efficiency
Product codes
WD Blue™ 3D NAND SATA SSD
A new dimension of storage
Built for enhanced reliability, WD Blue™ 3D NAND SATA SSDs offer high capacity, enhanced power efficiency, and blazing speed. Combined with 1.75M hours MTTF,4 up to 500 TBW,5 and a 3-year limited warranty, you get storage to depend on for years to come.
• 3D NAND SATA SSD for capacities up to 2TB with enhanced reliability.
• An active power draw up to 25% lower than previous generations of WD Blue SSD
• Sequential read speeds up to 560MB/s and sequential write speeds up to 530MB/s
• An industry-leading 1.75M hours mean time to failure (MTTF) and up to 500 terabytes written (TBW) for enhanced reliability.
• WD F.I.T. Lab™ certification for compatibility with a wide range of computers.
• Free downloadable software to monitor the status of your drive and clone a drive, or backup your data.
• Includes a 3-year limited warranty so upgrading your storage is worry-free.
A WD Blue 3D NAND SATA SSD uses 3D NAND technology not only for higher capacities (up to 2TB) than the previous generation WD Blue SSDs, but also to help reduce cell-to-cell interference for enhanced reliability.
Offering improved endurance, a WD Blue 3D NAND SATA SSD features an active power draw up to 25% lower than previous generations of WD Blue SSDs. And with less power used, you’re able to work longer before recharging your laptop.
Superior performance for high-end computing
For a variety of computing applications like gaming, HD media playback, or creative software, look to WD Blue 3D NAND SATA SSDs. Western Digital™ 3D NAND technology helps enable sequential read speeds up to 560MB/s and sequential write speeds up to 530MB/s for fast system boot-ups, quick application responses, and rapid transfer speeds.
An SSD is designed with no moving parts to help protect against data loss if it is accidentally bumped or dropped. And with 1.75M hours MTTF (mean time to failure), up to 500 TBW (terabytes written), and several error correction technologies, WD Blue 3D NAND SATA SSDs can help guard data for years to come.
Broad compatibility
With a certification from the WD Functional Integrity Testing Lab (F.I.T. Lab™), every WD Blue 3D NAND SATA SSD is verified for compatibility with a wide range of desktop and laptop computers. Every WD Blue 3D NAND SATA SSD goes through extensive compatibility and reliability testing to ensure it meets the high standards of the WD Brand.
Downloadable WD SSD Dashboard and Acronis software
Monitor your drive’s available capacity, operating temperatures, SMART attributes and more with the WD SSD Dashboard. Acronis® True Image™ WD Edition software, available as a free download, can clone drives and backup your operating system, applications, settings and all of your data.
Every WD Blue 3D NAND SATA SSD comes with a 3-year limited warranty, so you can be confident of your storage when you upgrade or replace any of your drives.
Product Description WD Blue 3D NAND SATA SSD WDS500G2B0A - solid state drive - 500 GB - SATA 6Gb/s
Type Solid state drive - internal - DEVSLP SATA low power mode, 3D NAND Technology
Capacity 500 GB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features DEVSLP SATA low power mode, 3D NAND Technology, S.M.A.R.T.
Dimensions (WxDxH) 69.85 mm x 100.2 mm x 7 mm
Weight 37.4 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 500GB Blue 3D NAND...
£53.95
