WD 500GB Elements 2.5" USB 3.0 Portable External Hard Dr...
WD 500GB Elements 2.5" USB 3.0 Portable External Hard Drive - Black
£46.16
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • WD quality inside and out
  • USB 3.0 and USB 2.0 compatibility
  • High-capacity in a sleek design
Product codes
For years, millions of people worldwide have trusted their data to WD hard drives, and its first concern is to reliably store that data. So this drive was built for durability, shock tolerance and long-term reliability. With this single drive you get compatibility with USB 3.0 devices and backward compatibility with USB 2.0 devices as well. With a huge capacity in a lightweight design, this drive is the ideal companion for users on the go.
WD Elements Portable WDBUZG5000ABK - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted
Power Source
USB bus
110.6 mm x 82.1 mm x 15 mm
130 g
Worldwide
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 500GB Elements 2.5"...
£46.16
