WD Caviar Blue16 drives combine 16 MB cache with 3 Gb/s transfer rate for lightning-fast performance in demanding desktop and workstation applications. Technologically advanced acoustics minimize noise and cool drive operation and enhanced reliability features help protect the drive and the data stored on it.
| Product Description | WD Blue WD6400AAKS - hard drive - 640 GB - SATA 3Gb/s | Type | Hard drive - internal | Capacity | 640 GB | Form Factor | 3.5" x 1/3H | Interface | SATA 3Gb/s | Data Transfer Rate | 300 MBps | Buffer Size | 16 MB | Spindle Speed | 7200 rpm | Features | IntelliSeek, SecurePark, StableTrac, Perpendicular Magnetic Recording (PMR), S.M.A.R.T. | Dimensions (WxDxH) | 10.2 cm x 14.7 cm x 2.5 cm | Weight | 0.63 kg | Microsoft Certification | Works with Windows Vista | Manufacturer Warranty | 2-year warranty |
General | |
| Device Type | Hard drive - internal |
| Capacity | 640 GB |
| Width | 10.2 cm |
| Depth | 14.7 cm |
| Height | 2.5 cm |
| Weight | 0.63 kg |
Performance | |
| Drive Transfer Rate | 300 MBps (external) |
| Seek Time | 8.9 ms (average) |
| Track-to-Track Seek Time | 2 ms |
| Average Latency | 4.2 ms |
Reliability | |
| Non-Recoverable Errors | 1 per 10^15 |
| Start / Stop Cycles | 50,000 |
Expansion & Connectivity | |
| Interfaces | 1 x SATA 3 Gb/s - 7 pin Serial ATA |
| Compatible Bay | 3.5" x 1/3H |
Miscellaneous | |
| Works with Windows Vista | Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running. |
| Compliant Standards | RoHS |
Manufacturer Warranty | |
| Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
| Min Operating Temperature | 0 °C |
| Max Operating Temperature | 60 °C |
| Humidity Range Operating | 5 - 95% |
| Shock Tolerance | 30 g @ 2ms (operating) / 300 g @ 2ms (non-operating) |
| Vibration Tolerance | 0.75 g @ 20-300 Hz (operating) / 4 g @ 20-500 Hz (non-operating) |
| Sound Emission | 28 dBA |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
