WD Black performance storage is designed to enhance your PC experience across heavier computing tasks whether you are a digital artist, video editor, photographer, or gamer. Available with up to 256MB of DRAM cache on higher capacity models, the WD Black drive is optimized for drive performance so you can spend more time experiencing the things you love most.
Product Description | WD Black WD6003FZBX - hard drive - 6 TB - SATA 6Gb/s | Type | Hard drive - internal - StableTrac, Advanced Format technology, DRAM cache | Capacity | 6 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | StableTrac, Advanced Format technology, DRAM cache | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 720 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 6 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 720 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 227 MBps |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 7.1 Watt (idle) , 9.16 Watt (read) , 9.16 Watt (write) , 1 Watt (sleep) |
Miscellaneous | |
Compliant Standards | RoHS 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 30 g @ 2 ms |
Shock Tolerance (non-operating) | 300 g @ 2 ms |
Sound Emission | 29 dBA |
