Western Digital WD Blue PC hard drives deliver solid reliability for office and web applications, and they are perfect for extra storage for desktop PC computing.
Product Description | WD Blue WD60EZAZ - hard drive - 6 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 6 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 5400 rpm | Features | NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T. | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 750 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 6 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 750 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 180 MBps |
Reliability | |
Non-Recoverable Errors | 1 per 10^15 |
Start / Stop Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 4.8 Watt (read/write) , 3.1 Watt (idle) , 0.6 Watt (standby) , 0.6 Watt (sleep) |
Software & System Requirements | |
Software Included | Acronis True Image WD Edition |
Miscellaneous | |
Compliant Standards | TUV Nord, RoHS 2011/65/EU, NMB-3 Class B, CAN ICES-3 Class B |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 30 g @ 2 ms |
Shock Tolerance (non-operating) | 250 g @ 2 ms |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
