WD 8TB Gold Enterprise Class 3.5" SATA 6Gb/s 7200RPM 256MB
£202.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Beyond expectations
  • Enhanced reliability
  • A world-class performer
  • Vibration protection
  • Play well with others
  • Form Factor: 3.5"
  • Type: Hard drive
  • Capacity: 8TB
  • Spin Speed (rpm): 7200rpm
  • Stock Status: In Stock
Product codes
Conquer tough workloads with enterprise-class WD Gold HDDs. This highly reliable solution for demanding storage environments provides up to 2.5M hours MTBF, vibration protection technology and a low power draw thanks to HelioSeal technology. Specifically designed for use in enterprise-class data centers and storage systems, the WD Gold SATA HDD delivers the world-class performance you expect from Western Digital hard drives.
Product Description WD Gold Enterprise-Class Hard Drive WD8004FRYZ - hard drive - 8 TB - SATA 6Gb/s
Type Hard drive - internal - Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, Enterprise Class Reliability, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
Capacity 8 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, Enterprise Class Reliability, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
Dimensions (WxDxH) 101.6 mm x 147 mm x 26.1 mm
Weight 715 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD 8TB Gold Enterprise...
£202.46
