WD 8TB Ultrastar DC HC320 7200 RPM SATA 3.5" Hard Drive
£271.16
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Lower capacity points needed for traditional IT workloads and applications
  • Enables higher capacities and reliability
  • Compatibility with legacy systems
  • Improved write performance and write splice protection
  • 12% faster than prior generation
  • Better head positioning and rotational vibration robustness
  • Form Factor: 3.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 8TB
  • Spin Speed (rpm): 7200rpm
Product codes
As the industry evolves to develop purpose-built solutions for growing data storage requirements, IT managers continue to rely on lower capacity drives that are economical to acquire, yet deliver quick and reliable data access for traditional data center applications. Designed to handle heavy workloads, Ultrastar DC HC320 is a drive that helps address economic and access requirements of many traditional IT workloads. The Ultrastar DC HC320 is designed for traditional storage and server applications as well as distributed and scalable computing, including block and file storage architectures.
Product Description WD Ultrastar DC HC320 HUS728T8TALE6L4 - hard drive - 8 TB - SATA 6Gb/s
Type Hard drive - internal
Capacity 8 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features Dual Stage Actuator (DSA), Secure Erase function, HelioSeal, 24x7 continuous operation, Enhanced Rotational Vibration Safeguard (RVS), advanced format 512e, Dynamic fly height technology
Dimensions (WxDxH) 101.6 mm x 147 mm x 26.1 mm
Weight 650 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£271.16
