WD Black 3.5" PC hard drives are designed to enhance the PC experience across higher intensity computing tasks for digital artists, video editors, photographers and gamers. The WD Black 3.5" PC hard drives are optimized for performance so you can spend more time experiencing the things you love most.
Product Description | WD Black WD101FZBX - hard drive - 10 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 10 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | StableTrac, Advanced Format technology, DRAM cache, Conventional magnetic recording (CMR), WD Dynamic Cache | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 748 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 10 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 748 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 263 MBps |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 4.6 Watt (idle) , 8.4 Watt (read) , 8.4 Watt (write) , 0.5 Watt (sleep) |
Software & System Requirements | |
Software Included | Acronis True Image WD Edition |
Miscellaneous | |
Compliant Standards | EU RoHS 2002/95/EC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 30 g @ 2 ms |
Shock Tolerance (non-operating) | 250 g @ 2 ms |
