WD Black 500GB Performance Mobile Hard Drive - 7200RPM SATA 6...
WD Black 500GB Performance Mobile Hard Drive - 7200RPM SATA 6Gb/s 32MB Cache 2.5"
£52.06
Delivery:
Standard: 1-3 working days
Key features
  • Inspiring performance and capacity
  • High resolution for a high definition world
  • Smarter than the average drive
  • Action meets stable traction
  • Efficient dual processing
  • Form Factor: 2.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 500GB, 500GB
  • Spin Speed (rpm): 7200rpm
Product codes
WD Black drives deliver improved performance that heightens the experience of your PC playground. These performance drives offer enhanced features over the previous generation to maximize system performance, allowing you to have more fun creating while spending less time waiting.
Product Description WD Black Performance Hard Drive WD5000LPLX - hard drive - 500 GB - SATA 6Gb/s
Type Hard drive - internal - dual processor, Advanced Format technology
Capacity 500 GB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 32 MB
Spindle Speed 7200 rpm
Features Dual processor, Advanced Format technology, S.M.A.R.T.
Dimensions (WxDxH) 69.85 mm x 100.2 mm x 7 mm
Weight 92 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD Black 500GB Perform...
£52.06
