We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
WD BLACK Gaming Hard Drives let you download the latest AAA titles while also keeping your ever-growing catalog of classics and favorites ready to play. Don't compromise on your game collection. Store more and game more with WD BLACK.
Product Description | WD_BLACK WD6004FZWX - hard drive - 6 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 6 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 7200 rpm | Features | StableTrac, Advanced Format technology, Conventional magnetic recording (CMR), WD Dynamic Cache | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 750 g | Localisation | Worldwide | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 6 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 750 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 229 MBps |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 8.7 Watt (read/write) , 7.9 Watt (idle) , 0.29 Watt (standby) , 0.29 Watt (sleep) |
Software & System Requirements | |
Software Included | Acronis True Image WD Edition |
Miscellaneous | |
Compliant Standards | RoHS 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Shock Tolerance (operating) | 30 g @ 2 ms |
Shock Tolerance (non-operating) | 300 g @ 2 ms |
Sound Emission | 28 dBA |
