WD Blue 1TB Desktop Hard Disk Drive - 7200RPM SATA 6Gb/s 64MB...
WD Blue 1TB Desktop Hard Disk Drive - 7200RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX
£43.24
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • A modern classic
  • Easy upgrade
  • Form Factor: 3.5" x 1/3H
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 1TB, 1TB
  • Spin Speed (rpm): 7200rpm
Product codes
Built to WD's highest standards of quality and reliability, WD Blue offers the features and entry-level capacities that are ideal for your computing needs. WD Blue is designed by the brand that you trust with the quality you would expect for a tested, proven, everyday storage solution.
Product Description WD Blue WD10EZEX - hard drive - 1 TB - SATA 6Gb/s
Type Hard drive - internal - IntelliSeek, NoTouch ramp load technology
Capacity 1 TB
Form Factor 3.5" x 1/3H
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 64 MB
Spindle Speed 7200 rpm
Features IntelliSeek, NoTouch ramp load technology
Dimensions (WxDxH) 10.16 cm x 14.7 cm x 2.54 cm
Weight 440 g
Designed For My Cloud EX2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD Blue 1TB Desktop Ha...
£43.24
