WD Blue 320GB 16MB 2.5" SATA 6Gb/SEC Internal Hard Drive
£39.91
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Low power consumption
  • NoTouch ramp load technology
  • Form Factor: 2.5"
  • Type: Hard drive
  • Interface Type: Serial ATA-600
  • Capacity: 320GB
  • Spin Speed (rpm): 5400rpm
Product codes
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
Product Description WD Blue WD3200LPCX - hard drive - 320 GB - SATA 6Gb/s
Type Hard drive - internal - NoTouch ramp load technology, Advanced Format technology
Capacity 320 GB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 16 MB
Spindle Speed 5400 rpm
Features NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
Dimensions (WxDxH) 69.85 mm x 100.2 mm x 7 mm
Weight 90 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD Blue 320GB 16MB 2.5...
£39.91
