WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
Product Description | WD Blue WD3200LPCX - hard drive - 320 GB - SATA 6Gb/s | Type | Hard drive - internal - NoTouch ramp load technology, Advanced Format technology | Capacity | 320 GB | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 16 MB | Spindle Speed | 5400 rpm | Features | NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T. | Dimensions (WxDxH) | 69.85 mm x 100.2 mm x 7 mm | Weight | 90 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 320 GB |
Width | 69.85 mm |
Depth | 100.2 mm |
Height | 7 mm |
Weight | 90 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 147 MBps |
Average Latency | 5.5 ms |
Reliability | |
Non-Recoverable Errors | 1 per 10^14 |
Start / Stop Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 1.4 Watt (read) , 1.4 Watt (write) , 0.55 Watt (idle) , 0.16 Watt (standby) , 0.16 Watt (sleep) |
Miscellaneous | |
Compliant Standards | RoHS, NMB-3 Class B, CAN ICES-3 Class B |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Shock Tolerance (operating) | 400 g @ 2 ms |
Shock Tolerance (non-operating) | 1000 g @ 2 ms |
Sound Emission | 17 dBA |
