WD Blue 750GB Mobile 9.5mm Hard Disk Drive - 5400RPM SATA 6Gb...
WD Blue 750GB Mobile 9.5mm Hard Disk Drive - 5400RPM SATA 6Gb/s 2.5 Inch - WD7500BPVX
£47.42
Delivery:
Key features
  • NoTouch ramp load technology
  • Low power consumption
Product codes
WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives. Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs. These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
WD Blue WD7500BPVX - hard drive - 750 GB - SATA 6Gb/s
Hard drive - internal
750 GB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock Guard, WhisperDrive, SecurePark, Advanced Format technology
69.85 mm x 100.2 mm x 9.5 mm
150 g
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD Blue 750GB Mobile 9...
£47.42
