We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | WD Gold WD221KRYZ - hard drive - Enterprise - 22 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 22 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 512 MB | Spindle Speed | 7200 rpm | Drive Class | Enterprise | Features | HelioSeal, advanced format 512e, OptiNAND technology | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 670 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 22 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 670 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 291 MBps |
Reliability | |
MTBF | 2,500,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 7.1 Watt (active) , 5.7 Watt (idle) |
Software & System Requirements | |
OS Required | Linux, Microsoft Windows Server, Microsoft Windows |
Miscellaneous | |
Compliant Standards | ROHS Directive 2015/863/EU, ROHS Directive 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 60 °C |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine wave |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine wave |
Sound Emission | 20 dBA |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
