WD My Passport 2TB Blue Portable USB 3.0 Hard Drive
Colours:
Key features
  • Auto backup
  • Password protection
  • Easy to use
Product codes
The My Passport portable drive is trusted to store the massive amounts of photos, videos and music you love. It fits comfortably in the palm of your hand, so you can easily take your treasured content everywhere you go.
Product Description WD My Passport WDBS4B0020BBL - hard drive - 2 TB - USB 3.0
Type Hard drive - external (portable) - password authentication, automatic backup
Capacity 2 TB
Hardware Encryption Yes
Encryption Algorithm 256-bit AES
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Features Password authentication, automatic backup
Power Source USB bus
Enclosure Colour Blue
Dimensions (WxDxH) 110 mm x 81.5 mm x 13.8 mm
Weight 170 g
Localisation Worldwide (excluding China)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
WD My Passport 2TB Blu...
