WD Red Plus 2TB 5400 RPM Serial ATA III 3.5" 128MB
£72.50
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • For Small or Medium Businesses
  • Exclusive NASware 3.0
  • Built for optimum NAS compatibility
  • 3D Active Balance Plus
  • 5400RPM performance class
  • Form Factor: 3.5
  • Type: Hard drive
  • Capacity: 2TB
  • Spin Speed (rpm): 5400rpm
Product codes
Packed with power to handle the small- to medium-sized business NAS environments and increased workloads for SOHO customers, WD Red Plus is ideal for archiving and sharing, as well as RAID array rebuilding on systems using ZFS and other file systems. Built and tested for up to 8-bay NAS systems, these drives give you the flexibility, versatility, and confidence in storing and sharing your precious home and work files.
Product Description WD Red Plus WD20EFZX - hard drive - 2 TB - SATA 6Gb/s
Type Hard drive - internal
Capacity 2 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 128 MB
Spindle Speed 5400 rpm
Features NASware technology, 24x7 continuous operation, Conventional magnetic recording (CMR)
Dimensions (WxDxH) 101.6 mm x 146.99 mm x 26.11 mm
Weight 570 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£72.50
