Packed with power to handle the small- to medium-sized business NAS environments and increased workloads for SOHO customers, WD Red Plus is ideal for archiving and sharing, as well as RAID array rebuilding on systems using ZFS and other file systems. Built and tested for up to 8-bay NAS systems, these drives give you the flexibility, versatility, and confidence in storing and sharing your precious home and work files.
Product Description | WD Red Plus WD60EFZX - hard drive - 6 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 6 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 128 MB | Spindle Speed | 5400 rpm | Features | NASware technology, 24x7 continuous operation, Conventional magnetic recording (CMR) | Dimensions (WxDxH) | 101.6 mm x 146.99 mm x 26.11 mm | Weight | 750 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 6 TB |
Width | 101.6 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 750 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 185 MBps |
Reliability | |
MTBF | 1,000,000 hours |
24x7 Operation | Yes |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
