We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Joining the original color of NAS, WD Red Pro continues the formula of success that has led the WD Red product family by adding support beyond consumer and small business markets into medium and large 8-16 bay business storage systems. WD Red Pro hard drives integrate WD's exclusive technology, NASware, to provide unparalleled support for drive compatibility, reliability, and performance.
Product Description | WD Red Pro WD221KFGX - hard drive - 22 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 22 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 512 MB | Spindle Speed | 7200 rpm | Features | Native Command Queuing (NCQ), Advanced Format technology, 3D Active Balance Plus, Multi-axis shock sensor, 24x7 continuous operation, Error Recovery Control, Conventional magnetic recording (CMR), OptiNAND technology, NASware 3.0 technology | Dimensions (WxDxH) | 101.6 mm x 147 mm x 26.1 mm | Weight | 670 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 22 TB |
Width | 101.6 mm |
Depth | 147 mm |
Height | 26.1 mm |
Weight | 670 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 265 MBps |
Reliability | |
MTBF | 1,000,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 10 per 10^14 |
Load / Unload Cycles | 600,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 6.8 Watt (read/write) , 3.4 Watt (idle) , 1.2 Watt (standby) , 1.2 Watt (sleep) |
Miscellaneous | |
Compliant Standards | ROHS Directive 2015/863/EU, ROHS Directive 2011/65/EU |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 65 °C |
Shock Tolerance (operating) | 40 g @ 2 ms |
Shock Tolerance (non-operating) | 200 g @ 2 ms |
Sound Emission | 20 dBA |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
