Wiser Multi-zone Kit 1 for Combi Boilers
Product codes
Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
One channel thermostat system with two radiator theremostats to start zoning your system. Suitable for Combi boilers. Set schedules for the room thermostat and radiator thermostats via the Wiser Heat app. Add more radiator thermostats to create more independent zones.
What makes Wiser wiser.
Wiser makes home personalisation affordable by allowing you to start with a room thermostat and build a full multi-zone system over time by adding radiator thermostats. Simply unscrew the existing radiator valve heads and screw on your new Wiser Radiator Thermostats.
  • Multi-zoning - build the perfect system by adding Radiator Thermostats as required
  • Works with Amazon Alexa
  • Eco Mode - combines weather compensation & optimum stop for maximum savings
  • Simplicity - standard wallplate, wireless devices
  • Remote Control - simple app with boost & away mode
  • OpenTherm® technology
Kit contains:
  • 1 x Room thermostat
  • 1 x 1 channel Heat Hub®
  • 2 x Radiator Thermostats
  • 1 x Thermostat stand
  • 1 x Thermostat wall bracket
  • 6 x AA batteries
  • 1 x OpenTherm module
  • 1 x Wallplate
  • 2 x M30x1.5mm ring nut
  • 2 x Drayton valve adapter
  • 2 x Danfoss RA valve adapter
Product Description Drayton Wiser Multi-zone Kit 1 - thermostat kit
Product Type Thermostat kit
Functions Humidity measurement
Power Source Battery
Package Content Thermostat, 2 x radiator thermostats, system hub, control interface module, 2 x Drayton valve adapters, 2 x Danfoss RA valve adapters
Connectivity Wireless - Wi-Fi
Frequency Band 2.4 Ghz
Display 2.4" - LCD
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Wiser Multi-zone Kit 1...
