Wiser Radiator Thermostat
Key features
  • Individual room control
  • Multiple sensors for high accuracy
Product codes
Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
Add additional single radiator thermostats to any Wiser Kit to create more zones and benefit from maximum comfort and energy savings.
What makes Wiser wiser.
Radiator thermostats enable your Wiser system to enter a whole new level of smart. With a direct connection to the boiler, they enable you to control on/off times and the temperature in individual rooms via the app. Simply unscrew the existing radiator valve heads and screw on your new Wiser Radiator Thermostats.
  • Smart Radiator Thermostat that mounts on most common radiator valves (M30x1.5mm and Danfoss RA)
  • Revolutionary, simple user interface incorporating a twist-top with spring-back for simple boost
  • Multiple temperature sensors for high accuracy
  • Automatic valve protection runs
  • Silent operation
  • Battery life of 2 years
Kit contains:
  • 1 x Radiator Thermostats
  • 2 x AA batteries
  • 1 x M30x1.5mm ring nut
  • 1 x Drayton valve adapter
  • 1 x Danfoss RA valve adapter
Drayton Wiser Radiator Thermostat - thermostat
Thermostat
Power Source
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
5.1 cm x 5.1 cm x 9.3 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
