Wiser Room Thermostat
Product codes
Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
Add additional room thermostats to rooms with radiator thermostats as a convenient way to view and change the room temperature. Works with all Wiser Kits
What makes Wiser wiser.
No wires, no installation, no mess. The wireless room thermostat is battery powered, and thanks to the handy table stand and wall clip, can be positioned anywhere.
  • Wireless thermostat - no wiring, no fuss
  • Multi-colour display
  • Capacitive touch buttons
  • Humidity sensor
  • Manual temperature adjustments
  • Battery life of 2 years
Product Description Drayton Wiser Room Thermostat - thermostat
Product Type Thermostat
Power Source Battery
Connectivity Wireless - Wi-Fi
Frequency Band 2.4 Ghz
Thermostat 2.4" - LCD
Dimensions (WxDxH) 7.6 cm x 2.5 cm x 7.6 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
