Your portable home cinema
Up to 120'' screen with 1.2:1 throw ratio
Multi-angle auto-keystone correction
Clear 1080p resolution images with auto-focus
Android TV™ with Google Assistant built-in
Entertainment with Dolby Audio
A perfect square projected at multiple angles
Mi Smart Projector 2 supports multi-angle auto-keystone correction across 3 axes and 6 directions to project a perfect square.
Smart hub of an IoT-enabled home
Use your voice to search for shows, control your projector and smart home devices, ask questions, and much more. Press the Google Assistant button on your remote to get started
Auto-focus ensures a clear image
The highly sensitive camera improves the focus speed, which also prevents thermal defocus, ensuring the image remains clear and sharp.
1080p resolution, for high-level clarity
1920x1080 Full HD (1080p) resolution*, the Mi Smart Projector 2 projects high-resolution images.
Only 28dB for a peaceful viewing experience
By staying below 28dB* in normal operating conditions, the whisper quiet projector won't interrupt your viewing experience.
Diffused light reflection for eye comfort
Mi Smart Projector 2 uses diffuse reflection. Unlike traditional LCD TVs, which deliver light directly to your eyes, diffuse reflection causes less strain on eyes, and is more suitable for the young and old.
1.2:1 throw ratio makes it possible to project a large display in a small room
You can easily adjust the throw distance to produce an image of 60''-120''. Now you can watch films, enjoy concerts and play games, all on the same wall.
Home cinema experience even when placed on a desk
Mi Smart Projector 2 adopts customized cabinet volume and matching caliber. The integrated structure of a large sound cavity and an ultra-long sound guide tube makes the sound rich and delicate. The frequency can also drop as low as 90Hz*. Connect to the Mi Smart Projector 2 through Bluetooth to make it your own desktop sound system.
Enjoy the comfort of immersive sound
Carefully calibrated by the acoustic master, the Mi Smart Projector 2 adopts dual channel virtual surround sound and supports Dolby decoding*. The life-like human voices and virtual surround sound make you feel like you are right in the action
Enjoy smarter entertainment
Simplify your entertainment experience with Android TV™*. Access thousands of movies and shows from various platforms in one place
Just the ports you need
With one HDMI 2.0 port, one USB 2.0 port and one headphone port, the projector supports 4K input and works with hard drives, game consoles, microphones and more, making it perfect for your entertainment needs
As compact and portable as a work of art
With a body size of 115x150x150mm and covered with fabric material on the front, it makes a perfect artistic addition to your home. Weighing only 1.3kg, pick it up and move it whenever you need
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
