The Sync Smart Home Alarm puts you firmly in control, giving you peace of mind, assured that your home is secure and protected. Check from anywhere in the world and receive alerts and notifications when your alarm is triggered, so you'll always be in the know - with no monitoring fees.
The Sync Smart Home Alarm 6 Piece Kit is completely wire-free, eliminating the need for cables running through your property. This means that you have the flexibility to take your home alarm system with you, if ever you move. It is also expandable, so you can design the perfect security solution to suit your home. You can add extra door and window contacts, PIR sensors, smoke alarms, smart plugs, keypads, water leak sensors and if you have a furry friend, you can opt for pet friendly PIR motion detectors. You can add up to 40 accessories and connect them seamlessly to your Sync Smart Home Alarm 6 Piece Kit.
Forget about long-term contracts, when you purchase the Sync Smart Home Alarm 6 Piece Kit you aren’t tied into any monthly rolling or monitoring fees.
What's in the box? The Yale Sync Smart Home Alarm 6 Piece Kit comes with:
1x Smart Hub
1x Yellow Siren
2x Motion Detector
1 x Door/Window Contact Sensor
1x Keypad
Product Description | Yale Smart Living Sync Smart Home Alarm - Family Kit - home security system | Product Type | Home security system | Power Source | Battery, power adapter | Internet of Things (IoT) Platform | Hue | Intelligent Assistant | Alexa | Package Content | Door and window sensor, keypad, siren, 2 x motion sensors, system hub | Max Supported Devices | 40 | Connectivity | Wireless, wired | Frequency Band | 868 MHz | Supported Host Device OS | iOS, Android |
General | |
Connectivity Technology | Wireless, wired - Ethernet |
Max Range Indoors | 200 m |
Supported Host Device OS | Android 4.2 (Jelly Bean) or later, iOS 9 or later |
Interfaces | LAN |
Features | Status notification, radio jamming detection |
Internet of Things (IoT) | |
Platform | Hue |
Motion Sensor | |
Detection Mode | Passive infrared (PIR) |
Detection Range | 12 m |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
