The BT 5960 Cordless Phone makes staying in touch at home easier, with no wires and ease of use, it's the perfect family phone.
Basic call blocking features prevent nuisance calls from interrupting your day, and a large wireless range means you can walk around the house without the phone signal dropping out.
There's also a loudspeaker, and ringer with adjustable volume, and a screen with caller ID, so you can see who's calling before you pick up. The clock has an alarm function, which makes the BT 5960 perfect for use as a bedside phone.
*You'll need a Caller Display service from your network provider to block nuisance calls and for text messaging features. Charges may apply.
Product Description | BT 5960 Quad - cordless phone - answering system with caller ID/call waiting + 3 additional handsets - 3-way call capability | Product Type | Cordless phone answering system with caller ID/call waiting + 3 additional handsets | Total Number of Wireless Handsets | 4 | Cordless Phone Standard | DECT\GAP | Speakerphone | Yes | Call Services | Voice Mail, Caller ID, Call Waiting, Call Transfer, Call Block | Display | LCD display - monochrome - Yes | Display Features | Blue backlight | Body Colour | Silver | Manufacturer Warranty | 1-year warranty |
General | |
Product Type | Cordless phone answering system |
Additional Handsets Qty | 3 |
Phone Features | |
Caller ID Type | Caller ID/call waiting |
Max Handsets Supported | 4 |
Dialer Location | Handset |
Conference Call Capability | 3-way |
Volume Control | Yes |
Ring Tones | 10 |
Handset Locator | Yes |
Indicators | Low battery/out-of-range indicator |
Additional Functions | Call timer, built-in clock, Alarm, built-in calendar, Intercom, phonebook transfer, Do not disturb |
Phone Memory | |
Phone Directory Capacity | 100 names & numbers |
Dialed Calls Memory | 10 |
One-Touch Dial Button Qty | 9 |
Caller ID Memory | 50 names & numbers |
Answering System | |
Recording Capacity | 60 min |
Display | |
Type | LCD display - monochrome |
Display Location | Handset |
Backlit | Yes |
Miscellaneous | |
Cables Included | Phone line cable |
Included Accessories | Power adapter, 3 phone charging stands |
Battery | |
Battery | 2 x battery - AAA type |
Capacity | 550 mAh |
Technology | Rechargeable - Nickel Metal Hydride |
Included Qty | 2 |
Talk Time | Up to 720 min |
Standby Time | Up to 120 h |
Dimensions & Weight | |
Width | 11 cm |
Depth | 5.5 cm |
Height | 17 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
The following resources are available for the BT 5960 Cordless Phone Quad Pack
