Snapdragon® G3X Gen 1 Gaming Platform For extreme Android gaming performance
The world’s first device* powered by the ultra-powerful Snapdragon G3x – an active-cooled gaming chipset with a [3 GHz] Kryo CPU, purpose-built to play Android games at incredibly high framerates over long play sessions.
[*At time of publication]
Console-class Control with HyperSense Haptics For complete precision and total immersion
Dominate touchscreen gaming or use the included Razer Kishi V2 Pro with microswitch buttons, analog triggers, programmable macros, and Razer HyperSense haptics for competitive AAA gaming.
6.8" 144Hz AMOLED™ FHD+ Touchscreen For fluid visuals and responsive gameplay
Gaming demands superior graphics and responsiveness to what handhelds and smartphones offer. An industry-leading 144Hz display ensures your games look better and run smoother than the competition.
Android, PC, Xbox, and Cloud Gaming For playing your favorite games anywhere
Whether you love Halo, Fortnite, Diablo, or Roblox, Razer Edge gives you access to a killer game library.
Play games from Google Play, or stream PC and Xbox games from your home or the Cloud[*].
[Third party hardware and services may be required]
Portable and Lightweight Design For AAA gaming anywhere
As pocketable as a smartphone, Razer Edge is the perfect travel companion to take your favorite games anywhere, and the ultra-light [ ]g design provides optimal comfort for extended play.
Powered by the Razer Nexus App For a dedicated Android gaming experience
Razer Nexus is a dashboard for Android gaming. Launch your games, explore recommendations, capture gameplay pictures and videos, or livestream your gaming to the world — all at the touch of a button.
Got an old games console lying around?
When you trade in your old device you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Razer Edge - 6.8" - Qualcomm Snapdragon G3x Gen 1 - 6 GB RAM - 128 GB - with Kishi V2 Pro Controller | Product Type | Tablet | Processor | Qualcomm Snapdragon G3x Gen 1 | Memory | 6 GB LPDDR5 | Storage | 128 GB - UFS 3.1 | Display | 6.8" touchscreen 2400 x 1080 / Full HD Plus | Input Device | Touch-screen | Integrated Webcam | Yes | Networking | Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E) | Dimensions (WxDxH) | 26 cm x 8.5 cm x 1.1 cm | Weight | 401 g | Bundled with | Kishi V2 Pro Controller |
General | |
Processor / Chipset | |
CPU | Qualcomm Snapdragon G3x Gen 1 |
Memory | |
RAM | 6 GB |
Technology | LPDDR5 SDRAM |
Storage | |
Main Storage | 128 GB - UFS 3.1 |
Display | |
Type | 6.8" - AMOLED |
Touchscreen | Yes |
Resolution | 2400 x 1080 (Full HD Plus) |
Widescreen | Yes |
Features | 144 Hz refresh rate |
Audio & Video | |
Camera | Yes - 1080p (front) |
Resolution | 5 Megapixel (front) |
Frame Rate | 60 frames per second |
Sound | Speakers, microphone |
Compliant Standards | THX Spatial Audio |
Input | |
Type | Touch-screen |
Communications | |
Wireless | Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E) |
Battery | |
Capacity | 5000 mAh |
Connections & Expansion | |
Interfaces Details | USB-C , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 401 g |
Sustainability Information | |
TCO Certified | - |
Customer return - item has been used and shows signs of use
Ref: HDRP 048428 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£213.44
