The 3M Ergonomic Mouse has earned an ease-of-use commendation from the Arthritis Foundation for its patented, vertical grip design that keeps your hand and wrist at a neutral angle, while the mouse works as a regular optical mouse. Grip the handle and rest your hand on the base. Use your thumb to left and right click. It is wireless and USB compatible plug and play and features optical sensor.
Product Description | 3M Ergonomic Mouse EM550GPS Small - mouse - black | Device Type | Mouse | Connectivity Technology | Wireless | Colour | Black | Orientation | Right-handed | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 3 | Features | On/off power switch | Battery | 2 x AAA type | OS Required | Linux, Apple MacOS X 10.4.x, Microsoft Windows Vista / XP, Apple MacOS X 10.5.x | Manufacturer Warranty | 2-year warranty |
General | |
Colour | Black |
Input Device | |
Buttons Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Battery | |
Type | AAA type |
Installed Qty | 2 |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
